Есть Avaya definity SI, которая соединена потоком с УПАТС №1 и 4пр. АДАСЭ с УПАТС №2. При звонке с УПАТС №1 на УПАТС №2 звонок проходит, разговор есть, но нет КПВ. Не знаю где это настроить:( Информацию, какую нужно предоставлю. Кто знает подскажите пожалуйста.
Настройки потока:
DS1 CIRCUIT PACK
Signaling Mode: isdn-pri
Connect: pbx Interface: network
TN-C7 Long Timers? n Country Protocol: etsi
Interworking Message: PROGress Protocol Version: a
Interface Companding: alaw CRC? n
Idle Code: 01010100
Slip Detection? n Near-end CSU Type: other
Echo Cancellation? nКод: Выделить всё
SIGNALING GROUP
Group Number: 4 Group Type: isdn-pri
Associated Signaling? y Max number of NCA TSC: 0
Primary D-Channel: 01B0816 Max number of CA TSC: 0
Trunk Group for NCA TSC: 33
Trunk Group for Channel Selection: 33
Supplementary Service Protocol: a Код: Выделить всё
TRUNK GROUP
Group Number: 33 Group Type: isdn CDR Reports: n
Group Name: Trikom COR: 95 TN: 1 TAC: *83
Direction: two-way Outgoing Display? y Carrier Medium: PRI/BRI
Dial Access? y Busy Threshold: 99 Night Service:
Queue Length: 0
Service Type: tie Auth Code? n TestCall ITC: rest
Far End Test Line No:
TestCall BCC: 4
TRUNK PARAMETERS
Max Message Size to Send: 260
Supplementary Service Protocol: c Digit Handling (in/out): overlap/overlap
Digit Treatment: Digits:
Trunk Hunt: cyclical
Digital Loss Group: 13
Calling Number - Delete: Insert: Numbering Format: pub-unk
Answer Supervision Timeout: 0
TRUNK FEATURES
Used for DCS? n
Suppress # Outpulsing? n Numbering Format: private
Replace Restricted Numbers? n
Send Connected Number: y
Send UUI IE? y
Send UCID? n
SBS? n Network (Japan) Needs Connect Before Disconnect? n
TRUNK GROUP
Group Number: 13 Group Type: tie CDR Reports: n
Group Name: Mejdurechenskii RES COR: 94 TN: 1 TAC: *63
Direction: two-way Outgoing Display? y Trunk Signaling Type:
Queue Length: 0 Incoming Destination:
Comm Type: voice Auth Code? n
Trunk Flash? n
TRUNK PARAMETERS
Trunk Type (in/out): immed/immed Incoming Rotary Timeout(sec): 20
Outgoing Dial Type: rotary Incoming Dial Type: rotary
Disconnect Timing(msec): 500
Sig Bit Inversion: none
Analog Loss Group: 9 Digital Loss Group: 13
Incoming Dial Tone? y
Answer Supervision Timeout: 0 Receive Answer Supervision? y
TRUNK FEATURES
Data Restriction? n
Used for DCS? n
Suppress # Outpulsing? y
Seize When Maintenance Busy: neither-end
Per Call CPN Blocking Code:
Connected to CO? y Per Call CPN Unblocking Code:
ADMINISTRABLE TIMERS
Incoming Disconnect(msec): 650 Outgoing Disconnect(msec): 1150
Incoming Dial Guard(msec): 40 Outgoing Dial Guard(msec): 1600
Incoming Glare Guard(msec): 500 Outgoing Glare Guard(msec): 500
Incoming Partial Dial(sec): 90
Outgoing Rotary Dial Interdigit(msec): 800
Outgoing Seizure Response(sec): 224
Programmed Dial Pause(msec): 1500 Disconnect Signal Error(sec): 240
Flash Length(msec): 540 Incoming Incomplete Dial Alarm(sec): 67
END TO END SIGNALING
Tone(msec): 350 Pause(msec): 150
OUTPULSING INFORMATION
PPS: 10 Make(msec): 50 Break(msec): 50
ATMS THRESHOLDS
TTL Type: 105-w-rl Far End Test No:
TTL Vendor: TTL Contact:
Trunk Vendor: Trunk Contact:
Trunk Length:
MARGINAL UNACCEPTABLE
Min Max Min Max
1004 Hz Loss: -2 21 -2 21
-Dev +Dev -Dev +Dev
404 Hz Loss: 9 9 9 9
2804 Hz Loss: 9 9 9 9
Maximum C Message Noise: 55 55
Maximum C Notched Noise: 74 74
Minimum SRL-HI: 0 0
Minimum SRL-LO: 0 0
Minimum ERL: 0 0
Allow ATMS Busyout, Error Logging and Alarming? n
TRUNK GROUP
Administered Members (min/max): 1/2
GROUP MEMBER ASSIGNMENTS Total Administered Members: 2
Port Code Sfx Name Night Mode Type Ans Delay
1: 01A1402 TN760 D t1-stan 4280
2: 01B1501 TN760 D t1-stan 4280
3:
4:
5:
6:
7:
8:
9:
10:
11:
12:
13:
14:
15:
