Short Code 0N
KrLL
Short Code 0N
Сообщение KrLL »
Имеется транк H.323 между IP Office и S8500.
По шот-коду звонки должны на него уходить.
Указываю 0XXXX, tel. number 0N
Все ОК.
Меняю на 0N, tel. number 0N или .
Проходит только первая или две первых цифры.
Что я не так делаю?
0XXXX - endblock
0N - overlap
сделай
0N;
Dial
В system - telephony
Dial Delay Time (secs): 4
Dial Delay Count 0
KrLL
Сообщение KrLL »
Только 0 проходит
1/18/10 11:36:18 PM-051ms Call Ref = 2517, Short Code Matched = System, 0N
1/18/10 11:36:18 PM-062ms Call Ref = 2517, Originator State = Dialling, Type = User, Destination State = Seized, Type = Target List
1/18/10 11:36:18 PM-091ms Line = 2, Channel = 1, Line Ref = 9395, Q.931 Message = Setup, Call Ref = 2517, Direction = From Switch, Calling Party Number = 1933, Called Party Number = 0
1/18/10 11:36:18 PM-287ms Line = 2, Channel = 1, Q.931 Message = CallProceeding, Call Ref = 2517, Direction = To Switch
1/18/10 11:36:18 PM-291ms Call Ref = 2517, Originator State = Dialling, Type = User, Destination State = Dialling, Type = Trunk
1/18/10 11:36:18 PM-303ms Line = 2, Channel = 1, Q.931 Message = ReleaseComplete, Call Ref = 2517, Direction = To Switch, Cause Code = 1
1/18/10 11:36:18 PM-306ms Call Ref = 2517, Originator State = Dialling, Type = User, Destination State = Clearing, Type = Trunk
1/18/10 11:36:18 PM-306ms Call Ref = 2517, Disconnect from Destination End
1/18/10 11:36:18 PM-051ms Call Ref = 2517, Short Code Matched = System, 0N не вижу тут ; !!!!!
KrLL
Сообщение KrLL »
Большое спасибо.
Неделю мучился :)
