День добрый.
Есть проблеемка есть 2 станции S8800 (СМ 5.2.1) and S8300 (СМ 3.1.1) между ними IP-trunk.
на S8300 подключен телефон 2099 - аналог.
когда звоню с 2277 который находится на S8800 выходит такая ошибка:
17:01:02 dial 2099 route:UDP|AAR
17:01:02 term trunk-group 2 cid 0xd6b
17:01:02 route-pattern 20 preference 1 cid 0xd6b
17:01:02 seize trunk-group 2 member 2 cid 0xd6b
17:01:02 Setup digits 2099
17:01:02 Calling Number & Name 2277 Y.Yerbol
17:01:02 Proceed trunk-group 2 member 2 cid 0xd6b
17:01:02 denial event 1191: Network failure D1=0x8b2e D2=0x50126
17:01:02 route-pattern 20 preference 1 unavailable cid 0xd6b
17:01:02 denial event 1012: No circ/chan avail D1=0x8b2e D2=0xd6b
17:01:02 reorder trunk-group 2 cid 0xd6b
17:01:04 idle station 2277 cid 0xd6b
настройки 2-х станц:
S8800
Group Number: 2 Group Type: isdn CDR Reports: y
Group Name: TAN SHOLPAN COR: 100 TN: 1 TAC: *002
Queue Length: 0
Signaling Group: 2
Number of Members: 3
Group Type: isdn
TRUNK PARAMETERS
Charge Advice: none
Digital Loss Group: 18
Answer Supervision Timeout: 0
CONNECT Reliable When Call Leaves ISDN? n
Replace Restricted Numbers? n
Send Connected Number: y
Send UUI IE? y Modify Tandem Calling Number? y
Send UCID? n
Send Codeset 6/7 LAI IE? y
SBS? n
QSIG Value-Added? n
Sign S8800:
Group Number: 2 Group Type: h.323
Remote Office? n Max number of NCA TSC: 0
SBS? n Max number of CA TSC: 0
IP Video? n Trunk Group for NCA TSC:
Trunk Group for Channel Selection: 2
TSC Supplementary Service Protocol: a Network Call Transfer? n
T303 Timer(sec): 10
H.245 DTMF Signal Tone Duration(msec):
Near-end Node Name: CLAN Far-end Node Name: TAN
Near-end Listen Port: 1720 Far-end Listen Port: 1720
Far-end Network Region: 9
LRQ Required? n Calls Share IP Signaling Connection? y
RRQ Required? n
Media Encryption? n Bypass If IP Threshold Exceeded? n
H.235 Annex H Required? n
DTMF over IP: rtp-payload Direct IP-IP Audio Connections? n
Link Loss Delay Timer(sec): 90 IP Audio Hairpinning? n
Enable Layer 3 Test? n Interworking Message: PROGress
DCP/Analog Bearer Capability: 3.1kH
S8300:
TRUNK GROUP
Group Name: Atyrau IP trunk COR: 1 TN: 1 TAC: *003
Dial Access? n Busy Threshold: 99 Night Service:
Queue Length: 0
Signaling Group: 2
Group Type: isdn
TRUNK PARAMETERS
Charge Advice: none
TRUNK FEATURES
Send UCID? n
trunk-group 2 Page 4 of 21
QSIG TRUNK GROUP OPTIONS
SBS? n
sign S8300:
SIGNALING GROUP
T303 Timer(sec): 10
Near-end Node Name: procr Far-end Node Name: CLAN
Far-end Network Region: 2
RRQ Required? n
IP trunk м/у S8800 and S8300
Re: IP trunk м/у S8800 and S8300
Судя по логам я бы проверил в порядке:
1. Сеть.
2. Поигрался бы с настройками Sig.
1. Сеть.
vsorokin
У меня в sig gr для H323 стоит DTMF over IP:in-band
а DTMF over IP:rtp-payload только для SIP с Asteriks -ом
настройка sig между S8800 и S8500:
SIGNALING GROUP
Group Number: 10 Group Type: h.323
Remote Office? n Max number of NCA TSC: 10
SBS? n Max number of CA TSC: 10
IP Video? n Trunk Group for NCA TSC: 10
Trunk Group for Channel Selection: 10
T303 Timer(sec): 10
Near-end Node Name: procr Far-end Node Name: KRI
Far-end Network Region: 5
LRQ Required? n Calls Share IP Signaling Connection? n
RRQ Required? n H245 Control Addr On FACility? n
DTMF over IP: out-of-band Direct IP-IP Audio Connections? y
Link Loss Delay Timer(sec): 90 IP Audio Hairpinning? y
H.323 Station Outgoing Direct Media? n DCP/Analog Bearer Capability: 3.1kHz
И все работает.....
SIGNALING GROUP
T303 Timer(sec): 10
И все работает.....
в network region всё нормально прописано? связь и кодеки с другими регионами?
