Avaya G450 Music on hold через слот v9?
michael_loginov
есть информация что можно сделать так, вопрос только как? никто не пробовал делать такое?
спасибо.
спасибо.
michael_loginov
c vval пока не разобрался как можно сделать, нашел вот что:olle писал(а):можно, прописываете vval, кладете на него сообщения или записываете их с телефона - указываете как музыку на холде
make an "add announcement XXXX" (XXXX is the desired extension for announcement).
In the "Annc Name" field put the name of your announce who must be the same name of your wav file, without the ".wav" .
In the "Annc type" field put "integ-mus".
In the "Group/Board" field put the location of your announcement board, if it's on an G450, put for example 001V9 (001 is the number of the media gateway in the configuration, and V9 is the location of the announcement board in the media gateway).
Make "enable filexfer"
In the "login" field put a login that you will use for your ftp connection
In the "password" field put a password that you will use for your ftp connection.
In the "Secure" field put "n"
In the "Board address" field put for example 001V9 (the location of the announcement board"
Make your ftp connection on the announcement board and put your wave file.
Test to call the extension of your announce for test it
Make a "change music-sources"
In the "type" field put "music"
In the "source" field put "ext"
In the next field put the extension number of your announcement
но вот уже на первом этапе "In the "Group/Board" field put the location of your announcement board, if it's on an G450, put for example 001V9 "
мне выдает "001v9" Must administer announcement board prior to assigning equipment - получается ее надо где то раньше указать? у меня просто слот 001v9 есть пустой.
Zaharov Alex
michael_loginov
Zaharov Alex
